My freezer was frosting up and then the refridgerator side would not be cool. I could thaw it out and when I plugged it back in it would work great for a couple of weeks until it would start to frost up again. I replaced the defrost thermostat and now it will not cool. Do I need a new temp. control?
The fan and compressor both work
Originally Posted by: tkerns  The fan and compressor both work There are two fans: one inside the freezer and the other one is next to the compressor. Are they both working? Quote:...I replaced the defrost thermostat and now it will not cool.. Can you describe it more detailed? Gene.
