Moved in to a new house and the water dispenser is not working on the fridge. Ice maker is great.
I have disconnected the line under the kick plate and no water flowed out of either end. The water line up through the freezer was not clogged with ice at all. Previous owners said this was working for them...but I'm skeptical.
I do not hear a hum at all for the dispenser. What do you think the main culprit is?
Water Inlet Valve? Switch in the door?
I am not sure what the solenoid is...
Thanks for the help!
Tom
