Mccreron10
#1 Posted : Tuesday, September 21, 2010 12:17:31 PM(UTC)
Mccreron10
Water comes into dishwsher and just sits their. I can drain the water out by hitting the drain button.Thats all it does.
#2 Posted : Thursday, September 23, 2010 2:40:33 AM(UTC)
Here is your tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10130990.pdf
Try removing power from the unit for 10 minutes or so to see if the unit will reset.
Try different cycle types to see if you can get the wash motor to run.
Try the diagnostics.
If all no good.
Check the motor windings for continuity.
If OK continuity check to see if the motor is getting 120 volts when it should.
