I need instructions on how to get to the evaporator fan blade to replace it. The current fan has a broken blade but I don't see how to get to it. I removed the fan cover, but there is no way to remove the fan blade through the same hole as the cover. Where can I find step by step instructions??
Originally Posted by: mikep13440  I need instructions on how to get to the evaporator fan blade to replace it. The current fan has a broken blade but I don't see how to get to it. I removed the fan cover, but there is no way to remove the fan blade through the same hole as the cover. Where can I find step by step instructions?? Mike, Here is the service manual for your machine, http://servicematters.co...ibrary/docs/16025860.pdfFor now you need to refer to page 27 for your access and removal of the evaporator fan. You may want to keep the manual handy for possible future repairs. Good Luck, :cool: :cool: :cool:
