How do I tighten the upper spray arm? I don't know how to remove the retainer snap spray. :eek:
Originally Posted by: Bostock  How do I tighten the upper spray arm? I don't know how to remove the retainer snap spray. :eek: Bostock, You really can't tighten the upper spray arm assembly, You will need to remove the spray arm assembly. The snap connector (at the tub top) can be screwwed off(turn counter clockwise) then remove the assembly. Part number: AP4111405
Then you can snap the center pin out and off and remove the spray arm from the assembly. Part number: AP4326785
Then you can check the outlet and spray arm for excess wear and tear,and replace the appropriate part(s). Good Luck, :cool: :cool: :cool:
