oven stopped working. no power to burners or stove or clock. when i turn on 2 of the burners clock comes on but burners do not.
Check your power supply with a multimeter you need to have 220 volts at the large terminal block where the pigtail comes into the range. There are three wires only red, white, and black.. White is neutral, you should be able to go from white to red, or black to red and get 115 volts, and red to black and get 220.
