I have a maytag refridge psd2450grq it is dumping water from the pan below the fridge... ice maker stopped working a couple of months ago - dont think its related - i have ice building up on the bottom of the freezer side. defrost problem? causing icing and melting and then over flowing?
Sounds like your defrost drain is plugged up, probably with ice. Nat
