I am trying to remove the dials for the dryer and washing machine. The small dials pull off easily, but the larger two for dryer turn on and washing machine do not feel readily easy to pull off. Is there some type of clamp or ring holding them secure? If so how do we remove?:)
Gently pry the center out of the dial. This will expose the retainer clip. Pull the clip and the rest of the knob assembly will easily come off.
