dogwalker418
#1 Posted : 15 years ago
dogwalker418
The sides of the fridge and freezer are hot to the touch around the doors. The fridge was working fine and only started this after being unplugged and moved. The inside of fridge is cool and freezer seems to be working fine as well. Could it be stuck in defrost mode? Defrost timer stuck perhaps? Any ideas?
#2 Posted : 15 years ago
I doubt it is a defrost problem as the fresh food temperature would be high.
Could be that your condenser coils are dirty.
Since this happened after a move perhaps there is a problem with the condenser fan.
dogwalker418
#3 Posted : 15 years ago
dogwalker418
I manually advanced the defrost timer and that solved the problem temporarily, but after a while it was back to hot sides. I have ordered a new defrost timer and hopefully that will solve it. What do you think?
#4 Posted : 15 years ago
I doubt it has anything to do with defrost but stranger things have happened.
The following should help explain my reasoning in my first post.
http://www.applianceaid.com/yoderloop.html
