schredder
#1 Posted : Tuesday, September 30, 2008 7:35:08 AM(UTC)
schredder
Greetings,
I am trying to diagnose a cooking problem with my range. My wife is convinced that the oven temperature is lower than what it should be according to the control setting.
I am thinking the temperature sensor is faulty. But, before I go throwing parts at the oven, what is the resistance spec for this sensor? I read for similar sensors that it is 1100 ohms at room temperature?
Thanks,
Chris
schredder
#2 Posted : Tuesday, September 30, 2008 12:51:19 PM(UTC)
schredder
I will check the resistance tonight and report back.
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Upper oven temperature lower than displayed by 75degrees (Oven Repair (including Ranges and Cooktops))
by BillIan 10/22/2014 12:41:56 PM(UTC)
Oven temperature low (Oven Repair (including Ranges and Cooktops))
by Yuan 5/20/2014 4:27:30 PM(UTC)
