Does anyone know if it is easy to replace the control board on a Maytag Neptune gas dryer?
It is starting to act very strange and someone told me to replace the board.
Originally Posted by: broncobcc  Does anyone know if it is easy to replace the control board on a Maytag Neptune gas dryer?
It is starting to act very strange and someone told me to replace the board. very easy. unplug it first. remove the sheet metal cover in the back. tilt the plastic housing (on top) towards the front. remove the screws that secure the board and the wire connectors. exchange the board and re-assemble.
It is starting to act very strange and someone told me to replace the board. Bronco, What do you mean by acting strange ? It may not be the control board at all, could be a bad touchpad assembly, What problem(s) do you have ? :cool: :cool: :cool:
