After about an hour on self-clean the diaplay shows F1 and then starts the cool down cycle. The oven is only somewhat clean.:confused:
OK Thanks. It does seem odd that the F1 code only appears during the cleaning cycle.:rolleyes:
That button itself may be sticking causing the code. I personally never use the self clean cycle. Nat
