onebeaut
#1 Posted : Monday, September 29, 2008 10:08:24 AM(UTC)
onebeaut
i purchased two valves for my maytag model no. msd2356aea. if i am reading the instructions correctly does one valve get eliminated? i have a dispenser and filter hook up. instruction say to cut off the y connection and redirect to lower valve. Is that correct? after cutting the y connection what happens to the valve? thank you, Vincent E. Butera
Use other water valves (Washer Repair)
by zuki1100 4/18/2019 3:53:11 PM(UTC)
Would you change water valves? (Washer Repair)
by NSXBill 3/10/2017 2:44:04 PM(UTC)
help with orientation of wire connectors to water valves. (Refrigerator & Freezer Repair)
by iamnotmad 1/7/2012 6:49:31 AM(UTC)
refrigerator water valves/ solenoids (Refrigerator & Freezer Repair)
by mharwell01 9/21/2009 11:59:10 AM(UTC)
