#1. Cannot find any reference to this model ANYWHERE - not even the Sears site.
Problem - water is not dispensing (ice is OK). Checked for water flow - have none to dispensor. Any ideas as to what could be wrong and how to fix? Thanks.
have you changed your water filter? Part # AP3710633 or AP3890610 if the filter is clogged you won't get water out the dispenser. Nat
Yes - it has been changed. Cannot get water with or without the filter.
