jjeyrock
#1 Posted : Tuesday, September 14, 2010 5:37:05 PM(UTC)
jjeyrock
Well the dishwasher was working fine untill the other day. And now it stuck in rince. You can put it in any other mode and it just goes back to rince now if you run the rince it seems like it works fine. I open up the door where the button didn't see any plugs loose didn't smell any thing burn up. The dishwasher just turn 2 and of corse its out of worrity.If anybody has some advise please share. I did turn off the breaker for awhile hoping that would reset it but it didn't. So please help if you can Thanks
#2 Posted : Wednesday, September 15, 2010 2:44:29 AM(UTC)
Replacement parts for AMANA ADB3500AWB Dishwasher - Undercounter | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10183592.pdf
Try running the diagnostics.
Unfortunately since disconnecting power did not rest the unit and everything looks normal, it sounds like the control board is shot.
