HapPnis
#1 Posted : Tuesday, September 14, 2010 12:50:46 PM(UTC)
HapPnis
8 yr old Frigidaire over/under has power but doesnt do anything past the lightbulb....tested the evap fan and it is definately bad...cant spin the shaft at all and it didnt have continuity. any and all help/suggestions appreciated.
Jim
#2 Posted : Tuesday, September 14, 2010 2:45:16 PM(UTC)
Jim,
Tap on the temperature control knob. Did the compressor start?
If it did, replace the temperature control.
If it did not, open the control box and bypass the temperature control. Did the compressor start?
If it did not, open the control box and locate the defrost timer (#23 on the diagram). Using a flat screwdriver, turn the timer shaft CW until it clicks. If the compressor would not start, turn it further until it clicks again. Post the results.
- The temperature control Part number: AP2151609
- The defrost timer Part number: AP2111929
HapPnis
#3 Posted : Tuesday, September 14, 2010 3:27:28 PM(UTC)
HapPnis
Gene,
thnx for the help...i did all that you suggested...thumped on temp control -- no go; have a stupid question; when you say to bypass the temp control and see if the compressor starts, I'm assuming by bypass you meant for me to just leave it disconnected?? -- no go; spun defrost timer cw one click -- no go; then for the 2nd click -- no go; for chits and giggles I checked to see that there were 120 volts to the temp control wires and also to the evap fan wires. I also took the back cover off to look at the compressor and relay and to my utter joy (not) I have a solid state 2 pc starter plugged into the compressor...any way for me to test that puppy? at this point I am about ready to go get my shotgun. oh yea; I also tested the temp control with my meter and didnt matter what way I turned the knob I got no response on the meter...no clue where to go or what I can do at this point to try and save this fridge without breaking the bank. It may be 8 yrs old but the interior and exterior are still in really great shape.
Jim
HapPnis
#4 Posted : Tuesday, September 14, 2010 6:21:57 PM(UTC)
HapPnis
If anyone else out there is knowledgeable or has an opinion to offer I am eager to hear what you have to say...tmrw is my Sunday and was hoping to get lucky and be able to get this thing finalized one way or the other. Thnx again !!
Jim
#5 Posted : Friday, September 17, 2010 4:52:07 PM(UTC)
Jim,
Sorry for the delay.
You said:
Quote:
...I also tested the temp control with my meter and didn't matter what way I turned the knob I got no response on the meter...
It means the temperature control is bad and it has to be replaced.
