Water pours out from under door upon initial start up surge of each cycle. Once running it does not leak. The door gasket on the sides and bottom is in good shape. Cleaned and tightened the pump gasket. Still leaks. SS tub. Any ideas?
Check your lower spray arm, make sureit is spinning freely & correctly. nat
The bottom spray arm assembly is not cracked and turns freely, although a little wobbly. The nylon bearings don't look worn, but there is about 1/8" of vertical movement of the spray arm assembly on the shaft. Thanks for your help!
