sharv999
#1 Posted : Sunday, September 28, 2008 2:23:48 AM(UTC)
sharv999
My Whirlpool top loader has suddenly developed a load grinding noise while draining water - I assume the noise is coming from the pump (perhaps a coin or something lodged inside?).
I am having trouble removing the back cover of the washer - any suggestions appreciated.
iamigor5@yahoo.com
#2 Posted : Sunday, September 28, 2008 4:01:45 AM(UTC)
iamigor5@yahoo.com
dont remove the back.....just lean washer back ,under the front you can see the pump. 2 hoses attached. remove 2 clips from pump and pull away from motor try running again with pump off for about 10 seconds in spin if noise is gone replace pump
sharv999
#3 Posted : Monday, September 29, 2008 12:13:17 AM(UTC)
sharv999
Thanks iamigor5 - that is certainly an easy way to check if the pump is the problem! Much appreciated.
Unfortunately the grinding noise remained after removing the pump, so it looks like I am up for a new gearbox :(
Are these easy to fit?
