mejohnsson
#1 Posted : Monday, September 13, 2010 2:16:41 PM(UTC)
mejohnsson
I have a GE Profile LSS 25XSTB SS about 4 years old. I have been having trouble with it not cooling sufficiently. It will go for several days and be OK with temps running 0 and 37 degrees in the freezer and food side. Then it starts to warm up to 35 and 55 degrees. The compressor and compressor fan is running but the evaporator fans do not run. Then after a day, or day and a half, the evaporator fans start again and everything cools off. Then I’m good for another week or so before it starts to heat up again.
Any suggestions?
#2 Posted : Tuesday, September 14, 2010 1:46:12 AM(UTC)
If you have no meter to check things, I would replace both the motherboard AP4436216 and the evaporator fan motor, AP4438809
