gregrao
#1 Posted : Thursday, September 25, 2008 6:37:30 PM(UTC)
gregrao
Hi. My stackable Frigidaire washer is leaking. I removed the front panel and ran it...is coming right from above the transmission/centerpost area. Checked pump and hoses and did not see any problems.
Do you think this is a bad centerpost gasket or something else? I have taken the agitator and basket off but I cannot free the tub from the center post assembly despite all the screws being removed. Do I need a hammer, or should I try to pry it off with a screwdriver or soap the centerpost? I am stuck.
I truly appreciate your help in diagnosing this problem and getting the tub off (assuming that needs to happen). Thanks. If you need my my cell, please email me and I will be happy to provide it.
--Greg
#2 Posted : Friday, September 26, 2008 1:08:29 PM(UTC)
Hi Greg,
You can find the complete instructions in the Service Manual.
Here are the break down diagrams for the Frigidaire laundry center Model FLSE72GCSA
