Power is to the outlet but the washer will not turn on Would anyone know what the problem may be
I hope this Service Manual will help you do diagnose the problem. Gene.
lg gives a two year part warranty on the control boards from the day you bought it. you have to see if you are getting voltage in to the controls in the back and voltage to the front board. always check for bad connections!!!!
