When the washer is filling it normally cuts off when the tub is full, but this one is not cutting off and will overflow on the floor. What would cause this it was just moved from one house to another?:(
The pressure tube may have come off during the move. Nat
When the washer is filling, if you push in on the timer knob, Does the water stop? if yes, check the pressure tube, It runs from the lower rt.side of the tub up to the water level selector switch in the console. If the water keeps coming in after you push the timer knob in, You need a water inlet valve!!!:)
