rjssdj
#1 Posted : Tuesday, September 23, 2008 5:21:29 PM(UTC)
rjssdj
Bake Element Didn't Work.replaced.stilldoesn't Work.broil Element And Convection Bake Element Work Fine
libertyappl
#2 Posted : Tuesday, September 23, 2008 6:15:15 PM(UTC)
libertyappl
make sure your wires are connected well and you may want to check where the go up the back behind the rear panel to make sure they are intact.
Oven not preheating to desired temp (replaced bake element and relay pcb) (Oven Repair (including Ranges and Cooktops))
by bds85466 2/7/2013 12:59:45 PM(UTC)
Replaced Bake element, now no heat from bake or broil (Oven Repair (including Ranges and Cooktops))
by adambmoose 8/13/2012 10:28:42 PM(UTC)
Replaced bake element. Still no oven (Oven Repair (including Ranges and Cooktops))
by ScottZ 10/27/2011 9:49:51 AM(UTC)
Replaced bake element,but oven won't work (Oven Repair (including Ranges and Cooktops))
by ant1828 2/19/2011 12:52:32 PM(UTC)
Replaced bake element, still no heat (Oven Repair (including Ranges and Cooktops))
by tobiasnaegele 6/27/2010 10:47:41 AM(UTC)
Replaced bake element and still not working (Oven Repair (including Ranges and Cooktops))
by needhelpplease 1/9/2010 7:06:03 AM(UTC)
Replaced Bake Element; Oven will not heat (Oven Repair (including Ranges and Cooktops))
by slkcd@suddenlink.net 1/20/2008 1:45:22 PM(UTC)
Replaced bake element; now nothing works but clock (Oven Repair (including Ranges and Cooktops))
by JK030150 1/9/2008 5:22:12 PM(UTC)
