asb237
#1 Posted : Friday, September 10, 2010 5:33:53 AM(UTC)
asb237
I am having problems with clothes getting "STUCK" in the area by the dryer lint trap. The plastic Drum Glide piece did come out and my husband put it back in, but things are still getting stuck and they are sliding around stuck while the dryer is on- when I open the dryer, clothes are marked with Grease from being trapped.
Can you please tell me if I should order a new drum glide and a new felt piece, or what are your suggestions to fix this "greasy" problem.
Thanks so much,
Aimee
Joe / APP Team
#2 Posted : Friday, September 10, 2010 6:19:03 AM(UTC)
Joe / APP Team
Thanks so much,
Aimee
Aimee,
Yes, you want to start by replacing the seal(s) and slide.
(click on numbers)
Part number: AP3669570
Part number: AP3419768
Part number: AP3423578
You should also check, the rear tumbler bearing / shaft assembly as well.
If it's distorted, loose, or shows excessive wear, you should also replace it, as well.
Part number: AP2044401
Good Luck,
