First: I love this website! :) Now the problem :( : My Broil element will not light. I have ordered, received, and replaced the Broil element and the thermal fuse, but still no heat. When I press the Custom Broil button and press ON, it clicks as though it turned on, but it never heats. What is the next thing to try? Don Saul
Do you have a volt meter? If you do, remove the back of the range, find the Broil element connections, Turn the broil on, and test for 240v between the 2 ends of the unit. BE CAREFULL!!!!! If you have 120v or less,carefully check ALL wiring, If good, Replace the EOC (electronic oven control)
