not enough water coming in the tub. WHAT COULD BE THE PROBLEM? HOW CAN I CHANGE WATER PUMP/ASSEMBLY
You have one of two problems, LOW water pressure or dirt plugging the SCREEN inside of the inlet valve. There is no pump to put water into the unit.
