The heating element appears to be getting to hot and melting the spray arm and other plastic. Suspect the problem to be the thermistat. I am interested in your diagnosis. Al
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Al, Replace the thermostat and check the heating element for possible short to the ground. If it would not help, replace the control board. - The thermostat Part number: AP2109201
