Neither the broiler nor oven setting will stay "on" more than 30 seconds once we set it. Just shuts itself off, no error code.
(Last year we had a problem and had a F5 code I believe and looked into replacing the ERC panel, had an electrician look at it and put it back and then the oven worked fine again, so we let that go.)
I'm wondering if this is something we can repair???? Thanks much!!
Serial#VG6328120
Originally Posted by: M1chelle  Neither the broiler nor oven setting will stay "on" more than 30 seconds once we set it. Just shuts itself off, no error code.
Serial#VG6328120 M1chelle, With your description of your present problem, and your previous failure code, I would have to reccomend, you start at replacing the control panel and or clock(touchpad and ERC,control board). Unfortunately, these parts have been discontinued by the manufacturer, and there are no substitute parts available. It may be time to consider a new oven. Good Luck, :) :) :)
