AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer will start to heat and then stop heating
Dryer Starts And The Gas Ignites For About 30 Sec Then It Stops Heating,though The Dryer Is Still Running
Originally Posted by: brian southern  Dryer Starts And The Gas Ignites For About 30 Sec Then It Stops Heating,though The Dryer Is Still Running Brian, Have you disconnected the exhaust vent tubing from the back of the machine and run a load with the vent off ? You may have a clogged vent or vent hood, causing the unit to cycle the hi limit thermostat, and turn off the heat. Try that first, if you still have a problem, contact us and we'll get you to do some more checks. :) :) :)
Dryer Repair
