Frost gathers at the top of the freezer compartment, the fridge part freezes some items regardless of temp control, which has no affect. The timer gear appears to be moving, can it still be bad?
Goofed on the model #, should be RT14BKXKQ01
Does the unit go into defrost cycle? Nat
Originally Posted by: mackisus ...Frost gathers at the top of the freezer compartment... Where in the freezer? On the back panel or somewhere else? Here are the break down diagrams for the Roper refrigerator Model RT14BKXKQ01Gene.
