Gene, Thanks so much for the repair instructions for the lid switch. The video was the key. I actually did the repair myself and I'm not a repair type person. The part was not expensive at all and you saved me so much money. I will always check out this forum first when something else needs repair. Thanks again. tahfrog
You are welcome. I'm glad we were able to help.
Hi Gene,
Thank you for sharing this video! I'm the most mechanically challenged person I know (seriously, I have trouble putting together a simple bookshelf) but with this video I was able to fix my washer all by myself. I'm super proud of myself and am happy to be doing laundry again.
Thanks again! :D Ali
You are welcome Ali. I'm glad it did work for you.
My washer needs the ld switch replaced but my aching is full of wet towels and water. How do I drain the machine to be able to fix it?
Originally Posted by: Monicab28  My washer needs the ld switch replaced but my aching is full of wet towels and water. How do I drain the machine to be able to fix it? What is the complete model number of the washer? Gene.
Kenmore model 3356472 Washing Machine
I replaced the Lid Switch and still I have no spinning or draining. What next? Everything else works.
Thanks...Denise
Hi Denise,
Does it agitate?
Does it do anything when it should drain and/or spin?
The model number you posted is incomplete. Verify and repost it please.
