frnak
#1 Posted : Tuesday, September 7, 2010 9:51:07 AM(UTC)
frnak
My dryer makes a clicking sound and the front panel lights up as it should, but the sensing light stays on and it just stops. It will not turn or dry at all. I have tried to enter test mode to get an error code, but get no response to the routine that is supposed to let me into test mode. Please help.
Frnak
#2 Posted : Tuesday, September 7, 2010 2:23:23 PM(UTC)
Perform the Test# 4 (step 4) as instructed in the Tech sheet. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GEW9200LW0 | AppliancePartsPros.com
frnak
#3 Posted : Tuesday, September 7, 2010 4:08:41 PM(UTC)
frnak
Thanks Gene. I was wrong. I got into the diagnostic mode and it passed all tests with giving any error code. Should I try to do the technician stuff in later tests? I will need to borrow the ohm meter or whatever it is to get this done.
#4 Posted : Wednesday, September 8, 2010 1:01:44 PM(UTC)
Yes, it should be the next step you'll do. Follow the instructions from the Tech sheet.
frnak
#5 Posted : Wednesday, September 8, 2010 4:11:28 PM(UTC)
frnak
I have tried step 4 and the ohm meter shows infinity at p2 on the control board. I took the toe panel off and am trying to test the resistance on the cables, but I CANNOT disconnect the sensor from the wire harness to test it. I have used pliers and tried to the pull them apart. What is the trick?
#6 Posted : Thursday, September 9, 2010 8:23:38 PM(UTC)
According to the instructions, if the result of the test was infinity, you have to measure the resistance between pins 1 and 2 of the connector P2 on the machine control board. You don't have to go to the wire harness and the moister sensor.
In such situation I believe the problem is a bad machine control electronics.
- The electronic control Part number: AP3604453
