Help I went out one day and left the door of my fridge freezer open. when i came home the fridge inside was really hot and the bulb light had blown the freezer was fine. i went out and replaced the bulb but the fridge wont work. any help or advice would really be apreciated Thanks Terry :)
Is the freezer fan working? You might want to remove the freezer panel and check for frozen evaporator coils.
Originally Posted by: richappy  Is the freezer fan working? You might want to remove the freezer panel and check for frozen evaporator coils. Thank you for your help in this matter
