I have a Speed Queen washer that when you turn it on, it kind of hums and then after a while you start to smell something hot. It does not run through the cycles at all. (doesn't fill, agitate,etc) Before this happened I had a problem with it leaking some. Sometimes it would leak, but then it would stop. I don't know if it's worth calling someone to repair or if it's something easy to fix.
The model number is LA650MXW1
