Freezer (bottom of unit) seems to be working properly. Refrigerator portion refuses to cool at all.
Kenmore was out of power for about a week , thanks to Ike. Now the freezed seems to work , but the refrigerator does not cool:mad:
I'm unfamiliar with the information you need. Select a "quick reply icon"?
There should be a damper door which the air flows from the freezer into the refrigerator, locate that and see if it's closed, if so that needs to be opened. The damper control maybe stuck nat
