Hello
I have removed the water filter and installed the adaptor. I also checked the water valve going to the unit. good water pressure.
Any idea's on what to check next?
Carefully pull the water line from the water valve of the back unit, use a bowl or glass and have someone push the water dispenser see if you get water in the bowl. If not then either your valve is out or the dispenser controls. Does it dispense ice? Nat
The ice dispecser is working. not sure if water is going to the ice maker. I will try to see if it is the valve after work. Thank you for the advice
If it doesn't dispense ice either it's probably in te dispenser controls. If you had a power surge or outage it usually takes the controls boards first. Nat
I verified that the valve is working.
good water flow to the ice maker and to the connector at the bottom of the freezer door going to the water dispenser.
No water or air will flow from the water line at the bottom of the freezer door to the water dispenser.
I turned the freezer temp down.
Any help on what to check next would be greatly appreciated.
It's probably a frozen water line. Turning the temp a little warmer may help. Nat
