celvig
#1 Posted : Wednesday, September 17, 2008 5:52:00 PM(UTC)
celvig
MY DRYER HAS POWER TO IT BECAUSE I CAN HEAR THE TIMER WORKING. BUT WHEN I PUSH THE SWITCH TO TURN IT ON IT DOESN'T DO ANYTHING. i HAVE REPLACE THE PUSH SWITCH.
ANY HELP
libertyappl
#2 Posted : Wednesday, September 17, 2008 5:59:17 PM(UTC)
libertyappl
If your unit is less than a year old, you mayhave voided the warranty when replacing the part, unless you had a certified tech do it.
But on another note, the timer works of 120V not 240V.
Try this go to your breaker box, throw your dryer breaker off for about 10 seconds and throw it back on then try the dryer.
Nat
SublimeMasterJW
#3 Posted : Wednesday, September 17, 2008 6:03:13 PM(UTC)
SublimeMasterJW
Check it out:spark ignitor.jpg On the left side in the rear where that heated air is vented to the outside a fuse is located that looks like this: Door spring.doc (193kb) downloaded 235 time(s). This dude will blow if that filter housing has a blockage. Replacing it will not completely fix that problema ifn you fail to remove that filter housing and clean out that puppy.That fuse by the way is connected in line with the door safety switch. So when it blows it is just like you have opened the door, HENCE the timer and everythang else wurks because power is not killed to the terminal. That is why it has smaller wires than the pigtail. Confused yet?:D
SublimeMasterJW attached the following image(s):
