For no reason, the display will show 'F1' and the stove starts to beep on a regular basis. Some times a reset will stop the beeping for several hours-sometimes only a few minutes.
Help !!!
Seems like a bad control module P# ap382954 available at appliancepartspros
Originally Posted by: dpk1000 For no reason, the display will show 'F1' and the stove starts to beep on a regular basis. Some times a reset will stop the beeping for several hours-sometimes only a few minutes.
Help !!! i am having same problems with my stove, im 17 female and pregnant and figured out the only way to stop it is to unplug it and im scared im gonna get electicuted and hurt the baby, i cant stand the beeping, its a electric jenn air, beeps randomly showing f1
Groups ready for retrieval: Senior Expert, Administrators Joined: 7/19/2007(UTC) Posts: 27,455
Most likely the problem is a bad control board or a shorted pad(s) on the touch pad. It is not dangerous, just annoying. Because you can not use it anyway, it's a good idea to keep it unplugged until it's fixed.
What is the complete model number of the unit? You can find it on the door frame.
