I have repaired ice chute door at least 4 times and the tabs that hold the dispenser front have broken. I have the new parts but I need to know the best way to install the new one. It will be more complicated due to the fact that I will now have to remove the complete unit in order to connect all of the new wiring, alot of which is inside the freezer door above the dispenser unit. Does anyone out there know where I can find specific instructions for this task?
Thanks Gene! I figured my problem out yesterday,simple really. The manual you refered me to is more comprehensive than anything I've found so far so I'm sure it will come in handy in the future.
I'm glad you were able to fix it.
