toth559
#1 Posted : Tuesday, September 16, 2008 3:48:24 AM(UTC)
toth559
I have a Amana electric dryer with no heat. Everything else is operative except for this fact. Does anyone know of any common problems with this particular unit? Any ideas? Mike
libertyappl
#2 Posted : Tuesday, September 16, 2008 7:14:34 AM(UTC)
libertyappl
Mike,
To start with make sure you have 240V at the plugin and the breaker isn't partially tripped. If that checks out the remove the rear panel and check the element & thermostats for continuity.
Nat
