dk2010
#1 Posted : Thursday, September 2, 2010 10:03:42 AM(UTC)
dk2010
Was standing water in bottom of tub after cycle was complete--Cleaned out drain hose,disposal clean,water trap/air gap cleaned.Replaced Timer after watching drain cycle not working during wash cycle--Now drain cycle works at short wash cycle but no draining occuring at end of wash cycle before drying cycle.Still have 1" of standing water at the end of the cycle.Any suggestions??
#2 Posted : Thursday, September 2, 2010 1:22:44 PM(UTC)
Remove the lower dish rack and the filter frame on the back. Unscrew and check the piston & nut assembly (#564 on the diagram).
You can find more useful information in of our previous posts: http://forum.appliancepartspros...er-wont-drain-fully.html
- The piston & nut assembly Part number: AP2617344
dk2010
#3 Posted : Tuesday, October 12, 2010 9:36:37 PM(UTC)
dk2010
I replaced the valve assembly and cured drainage problem for a short time--drainage issue has now re-occured--Is there a special way the timer has to be aligned when a new one is installed?I re-checked the new valve assenbly and everything seems to be OK. I did notice that the valve was in the open position when I re-checked the valve. Is that normal? Still 1" of standing water after a complete cycle has run. Very frustrating at this point.Any other suggestions? Thanks for your help.
