merikson
#1 Posted : Monday, September 15, 2008 10:22:40 AM(UTC)
merikson
I have a GE Profile Microwave, model JE1860.
All has been fine and suddenly no heating capacity. The control panel, timer, etc seem to work fine. The glass tray and rotator motor and fan motor seem fine. The light works fine.
Bad news is it will not heat a cup of water. Also notice that the sound is louder and somewhat deeper than when all was working well.
Any help would be appreciated. Any ideas on part replacement - is it the magnetron or a transformer? Do these things wear out?
Thanks,
Mark
#2 Posted : Monday, September 15, 2008 6:26:33 PM(UTC)
Hi Mark,
The first thing I would check is the upper door interlock switch and the diode (#6006 on the break down diagram). If there is nothing wrong then the problem is a bad magnetron (#1428 on the break down diagram).
In order to provide the right part number I need the rest of the model number and the result of your troubleshooting.
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
no heating elements work on cooktop or in ovens everything else is still working (Oven Repair (including Ranges and Cooktops))
by darinmac 9/9/2013 5:46:40 AM(UTC)
All works but no heating happening (Microwave Repair)
by meandmyguitar@socal.rr.co 12/26/2012 9:39:26 AM(UTC)
Loud hum no heating (Microwave Repair)
by jdbrazil 5/28/2012 7:55:17 PM(UTC)
Display out, no heating, only light (Oven Repair (including Ranges and Cooktops))
by manassas 1/25/2011 11:49:30 AM(UTC)
Oven no heating after Self Clean (Oven Repair (including Ranges and Cooktops))
by nickernoo 11/22/2010 1:24:36 PM(UTC)
Oven No Heating (Oven Repair (including Ranges and Cooktops))
by karl d Scheumann 7/14/2008 11:21:14 AM(UTC)
No heating in spite of power supply (Microwave Repair)
by srirangas 5/27/2008 4:37:44 AM(UTC)
Spacemaker JVM1660SB008: No Heating Loud Humming Noise (Microwave Repair)
by Doppan 1/27/2008 9:18:53 AM(UTC)
