supertime08
#1 Posted : Monday, September 15, 2008 10:09:09 AM(UTC)
supertime08
I have a defrost problem on a side by side. Fridge side is warm, just about no air coming from the top at diffuser. Freezer cold, frosted up. I defrosted freezer by letting the ice melt out, tested heater-ok by putting unit in the test mode from the control panel, thermistors both tested ok from panel, freezer fan is working. I believe problem is defrost circuit not turning on. After a couple days fridge gradually starts to warm up. My question, is this all controlled by the 8201528 control box assembly or is there another defrost control circuit unit? This unit is a whirlpool built fridge.
libertyappl
#2 Posted : Monday, September 15, 2008 10:17:50 AM(UTC)
libertyappl
Looking up the model.
Nat
libertyappl
#3 Posted : Monday, September 15, 2008 10:21:29 AM(UTC)
libertyappl
Your model is controlled by the electronic control which you have posted.
nat
supertime08
#4 Posted : Monday, September 15, 2008 10:36:24 AM(UTC)
supertime08
Thanks for the info.
libertyappl
#5 Posted : Monday, September 15, 2008 10:38:13 AM(UTC)
libertyappl
You're welcome!
hope that gets it going for you.
nat
