When I recently opened the door, it fell down quickly hitting my leg. I do not have a diagram, therefore I do not know if this is easy to fix and what parts I need. Thank you for your help
Remove the bottom access panels. Behind these panels are two door springs with the cables on each side. Most likely one of the cables is broken. Do not remove the other cable and use it as an example of its installation. - The door cable Part number: AP2038829
