My dishwasher has been working fine. Loaded it to wash and no lights. Nothing is working. There is power at the outlet. What should I be looking for? Does anyone have a wiring diagram? Thanks in advance.
There should be a wiring diagram located in the unit, either in the control panel or behind the kick plate. I haven't looked at your model but some models have a fuse. Nat
Where would a fuse be located?
If a electronic model with a readout, the fuse plugs into the control module behind the console. Also, check the power connections to the dishwasher behind the kick panel.
Thanks for all the help. I found the wiring diagram. I took the innerpanel apart, messed with the door switch and it started working. I am testing it now. Thanks again.
Let us know if we can help with anything else. Nat
