Replacement parts for WHIRLPOOL ET1MHKXMQ03 Refrigerator | AppliancePartsPros.comHere is a tech sheet
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202314273.pdfIf you mean that the evaporator coils are heavily fosted/ived up then you have a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 4 in Section 3) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 4 in Section 4) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 34 in Section 3) and measure it, should be 0 ohms when frozen. It is clipped to the evaporator coils. Also there were 2 different tech sheets for this unit one showed the thermostat as 56,000 ohms. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
