Dryer will start the flame will come on only for a minute then shut off . Ignighter will come back on but no flame. I cleaned every thing including vent ,any Ideas ?:confused:
Hi abe The problem with you dryer a bad coils on the gas valve. Remove the front panel and you'll get an access to the gas burner. The model number you provided is incorrect and I can give you the part number for the most common universal kit of coils, made by Frigidaire. - The part number for the new kit of gas valve coils AP2150379 Good luck. Gene. - The par number for the new set of coils
