I am having a problem with weather or not outer oven door glass trim pieces should go under the glass to expose the raw edges, or be on top of the glass, like the top and bottom trim pieces do. Diagram was not very clear.
If you look clocely at the trim pieces there is a track the glass rest in for the sides and one for the bottom trim. nat
