Maytag dishwasher (Type 779-0) is not yet two months old. When initially put in service made use of faucet adapter from previous unit. Connection was difficult. Installed adapter that came with unit . However, when water is turned on there is leakage from the top of the hose connection. Just slight, but constant during entire cycle. Is the adapter not correct piece; is ther something missing from the hose connection? Would calling the "Maytag Repairman" be a sensible alternative?
is the rubber seal in the adaptor? is the adaptor fastened snuggly to faucet?
The answer to both questions is yes.
