lynns
#1 Posted : Thursday, September 11, 2008 12:34:43 PM(UTC)
lynns
Hello, newbie here.
I did an Advanced Search but was unable to find an answer to my question.
Seven years ago I had the 'clock/oven control' and the 'control panel touch pad' replaced. I am again getting an F7 after several 30+ minute attempts of turning off the power. I called the GE Answer Center and they told me that the problem resides in the 'clock/oven control'.
Is there answer correct?
How do I access the the 'clock/oven control' module so that I can R&R?
Do I have to pull the oven from the wall?
Or is it the three screws above the open door?
Model JTP15WW1WW
libertyappl
#2 Posted : Thursday, September 11, 2008 12:45:26 PM(UTC)
libertyappl
You will have to pull the oven from the wall and remove the screws on the top plate to access the clock/control.
Nat
lynns
#3 Posted : Thursday, September 11, 2008 12:52:08 PM(UTC)
lynns
How do I pull it from the wall?
Thanks in advance.
libertyappl
#4 Posted : Thursday, September 11, 2008 6:07:17 PM(UTC)
libertyappl
Remove the trim around the sides, unscrew the fram and slide it out.
lynns
#5 Posted : Thursday, September 11, 2008 6:18:49 PM(UTC)
lynns
Thanks for the help.
I'll let you know what happens.
libertyappl
#6 Posted : Thursday, September 11, 2008 6:59:15 PM(UTC)
libertyappl
Keep us posted.
nat
